Port face area
IamDeMan
Banned
I am not sure how to determine what the sq in of the port face should be in a given enclosre. So here goes. The drivers are 18W3D4s friend has had them for awhile in his closet and wants to make a rather large low tuned home sub with them. their XMAX is like 13 and their SD is 186 sq in. Is there a way to determine what size it needs to be (Sq In) to avoid chuffing or any other port noise?
In the old WinISD I notice it has something it calls Vent Mach when creating a Ported enclosure with it. Is there a magic number of Mach to shoot for? or is this even related to my question in any fashiopn?
In the old WinISD I notice it has something it calls Vent Mach when creating a Ported enclosure with it. Is there a magic number of Mach to shoot for? or is this even related to my question in any fashion?
go to rear port velocity and remember to specify the max power you will be feeding your sub. aim to get most of the frequency response around below 17 m/s. That should guaruntee no port noise. If you have it above that point and at a very low or high frequency (20hz or 80hz for example), don't worry about it either.
I don't see that anywhere in WinISD.
PART 2
How accurate is WinISD at calculating the power handling? The box we are thinking of building shows 500 watts pushing the W3s to their XMAX at around 25hz in WinSID. However the rating of the subs is 500 ea. for 1000 total. Should he just get a 500 watt plate or use a 1000 watt plate? I know that power handling is greatly dependent on enclosure, but don't know how well WinISD calculates that.
IamDeMan
Banned
IamDeMan
/dev/null
IamDeMan
