port calculation help pls..
jackson12375
help me guys i want to come up with 35Hz i need the numbers please its urgent. thank you
lower is better for distance..meaning the "walkers" at the bus stops will hear you from farther..heh
All though lower frequencies travel further, a higher intensity (in terms of decibels) are achieved tuning the box higher.
Just an FYI.
No offense, but might want to throw up the numbers, just in case.
looks to be about 7.5cuft without port or sub displacement. Need port area to make any real determinations.
sqin = length
70 = 16.2
80 = 20.3"
90 = 25.8"
100 = 36"
110 = 839"
(all including .5" mdf as port walls ex:100=2.5cuft displacment)
longer = lower tuning from listed. All at ~35hz
Different bracing (less material) will result in a lower tuning with the same length
I cant give very accurate numbers until you give me port dimensions and how it will be built (such as using the wall of the box as part of the port)
jackson12375
jackson12375
phil
jackson12375
