Port a downfire box!?
FirstOnRaceDay
I have a 2004 F150 and will b getting back into deep,Techtronic P.E.B. music style. All I want is a way to port a customized downfire box with 2-Audiobahn DUB100 10's. Ported specs call for 0.70-2.30 cuft.The box I will get has 0.68 per chamber.I want to have it ported or should I have one built ported? I am ballin on a budget!!Any suggestions/help/comments are welcomed....
I appreciate the fb.I had a feeling that was the answer especially with little airspace there is.Just wanted to see if I could get around it.I will get another built or continue to look for ported enclosures.I see that there is one called Audiofire that comes ported with a single 10. I only have experience with sealed enclosure in car trunks and I know a ported one will give me the boom I am looking for. It's just that the 150 SCREW,all you have to work with is underneath the seats.
You can't port the box that is .68 per chamber sealed. You are going to have to get another one built, or just go sealed.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
697
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
870
842
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
FirstOnRaceDay
FirstOnRaceDay
Atlanta,GA
FirstOnRaceDay
    May 16, 2024
    May 16, 2024
