Popping sound! Caused by alternator??
roosm
Hey guys,
I have a wakeboat with a pretty nice setup, but recently I have started getting some really bad problems. When I have the stereo on while running the engine my 12" subs are making a popping sound, like a machine gun. There might also be some disturbance in the other speakers, but that is hard to tell since my subs are really loud.
I have 3 batteries. 1 start, 2 stereo. If I run the engine and all the supplies and the head unit from the start battery and use the stereo batteries to only power my 3 amps there are no problems. As soon as I put my battery switch to "all" (thus connecting the stereo batteries to the starter and alternator) the problem comes back.
I've been googleing the problem and first I figured it must be ignition noise from a loose or bad wire. But I've tried disconnecting one wire at a time from the coil with no difference (which I guess would exclude them from being the cause?).
Then I disconnected the alternator, which immediately cured the problem. So my question is. How can the alternator cause this problem and what should I do to solve it?
More info of the setup:
I have a 1F cap installed on the power wire to the 3 amps.
All the amps and speakers work perfectly with the engine off or the battery switch set on only the starter battery.
The RCA cable to my sub-amp is no where near the power lines to the amps.
The amps are powered directly from my 2 stereo batteries (with the cap in line) and grounded to the same 2 batteries. (No chassis since my hull is fiber glass). =)
Thanks!
//Mike
you need to run a thick ground wire from the 2 stereo batteries to the start battery so they will all have the same ground point. I would think this should solve your problem.
They are all connected with 1/2 gauge wire. And those haven't changed since long before the problem started. I'll measure the resistance of the ground cables and make sure there are no corrosion or loose cables.
Then I figured I'll check the ground from the alternator, motor and amps, one by one.
Thanks,
Mike
roosm
roosm
Gothenburg
roosm
