Sephious
To start things off, my system specs:
Speakers: CDT Audio CL-61A-25 Pro
Headunit: Stock Mazda 3 w/ LOC
Amp: Hifonics Zeus ZXI6010
Wiring: Alpine KWP-600K
I got everything installed today by a guy who has done hundreds of installs and is a fantastic installer. I caught him just before he went on vacation (so unfortunately can't troubleshoot the issues with him until he's back on Tuesday). I then took it home and tuned the amp to 22V for 121 watts to the speakers at volume 25 on the deck. Volume 25 is fairly flat when it comes to stock head units, which is why I chose it as the max.
Now onto the problems I'm having:
Number 1: ***SOLVED***
Alternator noise. When the car is on the alternator makes noise through the speakers. When you rev the engine the noise changes and gets faster.
What I've done to troubleshoot so far: Disconnected the RCA's with the car still running. The noise stops. So it's not a power wiring or speaker wiring issue. I'm thinking it's possibly a ground loop and grounding the deck to the same place the amp is will fix it. Any thoughts?
EDIT: I've tried a ground loop isolator and that did not solve the problem. Could it still be the fact that the stock deck is grounded to a different (or possibly crappy) point?
Number 2: ***SOLVED***
Popping noise at louder volumes. I can't pin down an exact level where the popping noise happens as it only happens with certain frequencies, mainly hard midbass hits. If I had to guess it starts happening around 50 watts 0dB 1000Hz tone, unknown actual wattage listening to a song.
I don't even know where to begin diagnosing this one.
Please help, so when the guy gets back from his vacation he can fix this!
