whitedragon551
Moderator
I love SQ, but cant use WinISD to save my life. Normally I pick up on software easily, but this one for some reason gives me issues. Anyways can some one model this up for me:
The help would be appreciated.
Sub is a single 4. It will be on an under rated 300@4. I need it modeled up in a single sub configuration for a sealed box, a single sub ported, and both subs ported on an under rated 420@2.Specifications: *Power handling: 125 watts RMS/200 watts max *VCdia: 2" Le: 2.86 mH *Impedance: 4 ohms *Re: 2.93 ohms *Frequency response: 32-500 Hz *Fs: 32 Hz *SPL: 85 dB 1W/1m *Vas: 1.64 cu. ft. *Qms: 9.72 *Qes: 0.73 *Qts: 0.68 *Xmax: 8 mm *Dimensions: Outside diameter: 10-1/4", Cutout diameter: 9", Depth: 5-1/2".
