Polyfill
First, don't use polyfill in an attempt to "make a box larger", it does effect the subs response, just not in the linear make-box-appear-x-larger way that enclosure guides say.
Second, don't use polyfill in a ported enclosure unless it's just a thin layer attached to the walls, polyfill damps (reduces) resonance, and ported boxes rely on resonance to work...
Polyfill can improve the SQ of a ported enclosure that is built too small or ported too high, but pales in comparason to actually building it the correct size and tuning it properly in the first place.
In short, if you aren't building a sealed enclosure, don't concern yourself with polyfill.
That didn't really answer either of his questions... I was wondering the same things he was.
with a ported box you may want to stick it to the sides so it wont fly out of the port. you will not need do factor the fill in to tuning, just add some untill you get the sound you like.
fiy, it wont make that big of a diffrence in a ported app.
kfx450r
kfx450r
Hammond, Louisiana
thevic24
BP1Fanatic
BP1Fanatic
