polyfill question
hdave
hello, i made my first sealed box ever (made a few ported ones before though)
anyways, the INTERNAL dimensions are 13.5 x 34.5 x 4, so its about 1.07 cubic ft
i was just wondering, how much polyfill should i put in it?
this is for an oz matrix elite 12 dual 4, powered by an arc kar 1000.2t @ 2 ohms (approx 900 rms)
i listen to mostly rap, a bit of reggae, and hardly anything else
1. how much polyfill should i use?
2. where do i get polyfill from?
okay here are a couple pics of the box (1.07 cu.ft sealed)
the sub will be inverse mounted (oz matrix elite 12)
and a pic of the amp powering it (arc kar 1000.2t)
looking good man. you should be able to find polyfill at the closest wallmart. is in not the same stuff they use in cheap pillows? and as for how much it depends on how much larger you want your box to seem
There is no right or wrong answer here.
A properly sized enclosure shouldn't need any polyfill at all.
Other than that, play around with the amount of polyfill and see if you like/don't like the changes in sound. Keep in mind the changes will be small, so don't expect huge dramatic changes.
Buy a couple pounds of the pillow stuffing at Walmart. Start with no polyfill and listen. Try putting in 1lbs and listen again. Try adding .5lbs more and listen again. If you don't like it, take some or all of it back out.
hdave
hdave
Toronto, Canada
squeak9798
