Polyfil benefit with FI SSD high QTS option ???
memphis_vette
Redding, CA
I have 2 FI SSD 10's that are down firing in a box under the rear seat of my truck. The box is approx .48 per woofer after displacement. The subs are fully loaded with the sealed high QTS option.
FI states these subs work in a .2-.4 cube box with the high QTS option.
My question is will I see any benefit to adding polyfil to my box?
Thank you for your time
Can I run the subs in a ported box although they have the high QTS sealed option? Would they sound ok or hurt anything?
The subs currently hit the lows just fine but it's the upper end that is pretty weak. I listen to a lot of rock and that strong punch isn't really there. I figured the polyfil would make them more responsive or punchy?
Polyfil could help slow some back waves and improve your upper sub bass response. You could also add some mass in the box to bring the volume down to ~.2 cubes per sub and see if that helps.
I'll give the polyfil a try, if not I'm only throwing away a few dollars.
awesome, i'd say you would prob get more out of the subs if they were facing forwards instead of downwards, but you prob have limitations stopping you from doing that.
It has benefit espeically on sealed boxes. Just look online and find a calculator for how much to add. There is a ratio that you use. It will help you pick up some low end and it works on boxes that were made smaller than spec. It makes a sub in a smaller box think the box is a bit larger.
...your subs are self aware?!
Glad they stepped up and replaced it! I honestly would have thought it was super petty if they didn’t just swap it out for you still being under...
Buck has been my go to since I got into builds, currently he’s unavailable and hopefully back at his passion soon (for privacy I’ll leave it at...
memphis_vette
memphis_vette
Redding, CA
bubbagumper6
just call me KeV
    Apr 27, 2024
just call me KeV
    Apr 27, 2024
