poly fill question?
You would have to use some adhesive to keep it from blowing out the port. In ported boxes it acts differently than sealed. I tried it and had no different results in a ported enclosure. Sealed, thats a different story, my low notes came out and the subs had a tad more excursion.
Poly fill is always a crap shoot. It may do something audible and it may not. The only benefit to it is stop standing waves.
not correct for subwoofers... with subwoofers the polyfill actually tricks the woofer into thinking the enclosure is larger than it really is by dissipating heat generated inside the enclosure. Normally without the fill the heat causes the air to stiffen in the enclosure but with some of that heat getting dissipated the air doesn't stiffen as much. This in turn tricks the woofer into performing like it is in a larger enclosure.
What kind of results?
I've noticed with some woofers I've gotten them to play lower and it sounds cleaner on the low notes... I've only done it with home subs, never tried it in my car but I'm assuming I'd get the same results. It is also woofer dependent since some subs are much more sensitive to enclosure size than others. Subs that are more particular to what size of enclosure seem to have more audible results.
no your not right, that is just a byproduct of using it. The correct usage is to dissipate standing waves.
dissipating standing waves isn't worth the effort in a subwoofer the low frequencies hardly have any standing waves to begin with due to the wavelength being so long. Most people use polyfill in subwoofers because they have a smaller than optimal enclosure. Now when using fill with a mid then yes it's primary function is to absorb standing waves.
I have a sealed box with two 15s in it. They would not hit lows below 38hz. I filled each chamber with 1.5lbs of polyfill. My roof shakes on low notes now //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
most people use capacitors to supplement their electrical systems as well doesn't make it right.
how is it not correct to use polyfill to make a small enclosure more optimal? It has been proven time and again that in many cases it can make a big difference in how low the woofer can play... So using it to get rid of standing waves is the only reason you should use it? Would you explain why it shouldn't be used for another reason?
It's not correct because it's a band aid. The correct way is to build the correct enclosure before hand. Your also ignoring the fact that standing waves make the enclosure seem smaller and inhibit low end response and clarity.
s.l.a.b
s.l.a.b
austin,tx
snyderd758
