if you pack it tight, you defeat the purpose....i packed mine in tight in the back of the box....
You do know that the air in the port travels in AND out right?hijack
Do you guys do anything to secure your polyfil in slot port enclosures? I would it imagine it comes flying out.
/hijack
It will be slightly tighter and will have a very slight difference in low end. Adding polyfil will smooth things out some and will give a slightly increased low end. To the ear, there won't be a huge difference. Also, the difference from .86 to 1 cube isn't going to be a large difference anyways.OK guys, call me retarded but instead of using 1728 in^3, i devided by 1528 in^3 for my box dimensions...so its about .98 ft^3 and needs to be just over 1ft^3.
If I use polyfill, will this make the box OK to use? Whats going to happen when using a box thats slightly too small?
