Polk pad 4000.4
mylows10
B2,singer,ampere rep
Item(s) for Sale: Polk pad 4000.4
Used very little signs of it tho. Mint
Electrical
Total Frequency Response 20Hz-20kHz*
Signal-to-noise (Referenced to rated power) 105 dBA
Distortion at Rated Power
Minimum Impedance Bridged 4 ohms
Minimum Impedance Not Bridged 2 ohms
Protection Circuitry Thermal, DC offset, reverse DC voltage and short circuit; fuses: one 40 Amp and one 35 Amp ATC*
High Pass Filter
Filter Slope 12dB/octave*
Filter Frequency 20Hz-4kHz (front)/20Hz-4kHz(rear)*
Low Pass Filter
Filter Frequency 50Hz-5kHz(front)/50Hz-5kHz(rear)*
Effective Damping Factor >100*
Max Sensitivity 200mV-6V dB
Dimensions
Cabinet Dimensions
Height 1 13/16" (4.60cm)*
Width 10 15/16" (27.78cm)*
Depth 6 3/4" (17.14cm)*
Product Weight (each) 5.0 lbs. pounds
Without Panels
Amplifier Specs
Channels 4*
Channel Notes Bridgeable Class D MOSFET*
12V & Ground Cable Gauge 4AWG*
Amplifier Power Specs
RMS Power at 14.4V
Watts per channel NOT bridged @ 1 kHz
4 ohms 125 watts
2 ohms 200 watts
Watts per channel bridged
4 ohms 400 watts
Price: $200 obo
USPS flat rate
Item Pictures: View attachment 26548139
mylows10
mylows10
monterey , ca
mylows10
