Sold Polk Dx12.4...Pair For Sale....
only126db
I have two 12's for sale... $40 each
These were test boxes, you can have them if you want them or just the subs
Model DX12.4....
Local pickup only...
Hemet Ca. 92543
Here are the specs from Polk Audio:
Woofer 12" Diameter (30.48cm)
Polymer Composite Subwoofer
Electrical
Overall Frequency Response 20-200Hz
Nominal Impedance 4 ohms
Power Handling (continuous) 400 w
Power Handling (peak) 800 w
Efficiency 86 dB
Voice Coil Diameter: Driver 2" (5.08cm)
Magnet Weight 40.00 oz.
Driver Mounting Depth
Top Mount 5-1/4" (13.34cm)
Bottom Mount 5-3/5" (14.22cm)
Cut-out
Driver Cut-out Diameter 11-1/8" (28.26cm)
Theile/Small Parameters
Recommended Enclosure .88 cubic feet sealed
Resonant Frequency 26.3Hz Hz
Qms 6.71
Qes 0.63
Qts 0.58
Vas 2.80 cu ft. / 79.3L
Cms 213.1 Micro Meters
Bl 13.4 Tesla Meters
Sd .553sq. ft. / 0514sq m
Winding Width 1.0in / 25.4mm
Xmax (linear) .343in / 8.7mm
Xmax (mechanical) 1.0in / 25.4mm
Le 1.5 mH
Mms 172.6 g
Driver Weight 8lbs 3oz / 3.7kg
Vd .062cu. ft.
Other
Product Weight 8.30 lbs.
only126db
only126db
Houghton Lake MI
only126db
