plz explain right way
you can run 1 power wire and 1 ground wire, and use a distrobution block to split it out into 2 wires for each power and ground, and run the remote turn on from on amp to the other then to the head unit. then just plug in the rcas from both amps to the head unit and you should be golden.
people on here have a tendency to not use correct grammar online and recently it's started bugging the piss out of people on here.
plus, half the time we don't kno what the Fuck you're saying when you don't spell correctly or make no sense at all and it makes it harder to read. //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Hmmm....look's like someone else need's help.....//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
yeah like adioboi or whoever that jackass from ohio was, but this guy just ask what block his replier(lol) would use. he didn't ask which as the coldest or anything //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif.
as for what to use, just hit up ebay and pick a cheap one. if you want to though you can get a d block with a voltage readout but doesn't seem like you would need that.
jj4475
jj4475
ill
dkguitarist
