plz check my wiring. im not sure on some of it
silentsigma
so im trying to install my HU (kenwood x590)
i have 2 amps, one for my speakers and one for my sub
below is a picture of the manuel and in red is where i think i should connect it too.
here are the connection im not too sure about
yeah im a little confuse. there is 2 place that goes to the antenna? and 2 places for to the amp?
The subwoofer amp would connect to the subwoofer preout RCA's, and the speakers would correspond to the correct L/R preouts. You shouldn't do anything with the antenna, it isnt involved here...
Both amplifiers need to be connected to the turn on lead (the first connection on that diagram.) You can run them both to it, or run one to it and daisy chain the second off of it.
anyone else can't see the picture?
well it's not where the RCA goes. it's the HU wiring itself.
1) P.cont (power control wire)
2) Ant. Cont (mother antenna control wire)
3)mute ( TEL mute wire)
4) Illumi ( Dimmer control wire)
5) Ext. Cont (external amplifier control wire
those are the 5 wires i don't have a clue about and don't know where is should hook it up too or even if i do need to hook it up.
im only mentioning my systems so you guys know what im trying to install my HU too and not just stock speakers
that first one i believe is so the amp turns on with the car you need to connect that......not sure about the next 2.......the fourth one dont worry about because you dont need it.........the fifth one is if you have like a remote level control for your amp...............if that helps at all
1 is where you connect the remote wire for your amps
2 is where you would connect if you car has a power antenna
3 is if you had something like a car kit for your cell phone that has an output to
mute a radio when the phone is in use
4 is what you would hook up if you want your radio to dim at night when you switch on your headlights
5 is for things like on kenwoods older amps that allow the radio to open and turn on the fans
thanks a lot for the help. just hook up my HU and it sounds great. no problem at all //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
silentsigma
silentsigma
fontana,CA
silentsigma
