Plywood
96civ
I'm in the process of constructing kick panels. Right now I'm constructing the baffles for the 6.5's... I'm going to do something similar to what this link shows, http://web.njit.edu/~cas1383/proj/mdf/index.htm, but instead of having everything MDF I was hoping to have the mounting ring be MDF (where the speaker is actually mounted) and the flush ring (the thinner ring) be either 1/4"-1/2" plywood, depending on the speaker. Would having a plywood ring resonate for this relatively low power application (50-100WRMS), or should I go for it?
I would tend to think if you deaden your kicks properly you shouldn't run into any problems. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
96civ
96civ
Indianapolis, IN
ramos
