Plexiglas engraving
^Good information.
You could always find a bead/sandblaster and use that for the frosting effect as well.
I'm interested in what you'll be engraving. Should look good - any plans to light it up?
I used a coned-shaped rotary attachment on my Dremel to engrave a Z emblem on the amp rack of my 300zx. It turned out well, but I don't have pics since I'm not at my home computer
returned
and sandpaper > dremel because it will make the engraving even
media blaster > sandpaper
because sandpaper will usually leave lots of random deep scratches. ive tried, it does not look smooth - maybe some 1000 grit or something might have worked better, i tried with 440 wet paper.
in recent history, i've used a woodburner with various tips achieve the desired effect, it doesn't jump around as much as the dremel or other hand rotory tools.
The plan calls for LEDs or cold cathodes to shine on the plexiglas highlighting the engraved area
thoughts on how do do this the best?
the woodburner sounds like it could discolor the plexi, but thats just me assuming. best bet is to print out your design (backwards) and tape it to the plexi, and "trace" your engraving into the plexi using the print as a template.
if you want to be neat, you could tape the whole surface of the plexi, and use an xacto knife to cut out the negative areas and sandblast them, then etch with a dremel to get a 3d looking effect.
its all about texture. CCFL's are great with plexi, just put it under the edge and try to hide it.
Radioflyer97
C.E.O.
Radioflyer97
earth (for the moment)
req
