Please help
  • 1
dbolm666
i need a site where i can buy cheap amps, i have about 200.00 to spend, and they have to push 200w rms, to each sub, i have two kenwood tornados 12'' w3003's. any amps that are cheap i gotta get one, i don't care if it's sony, jbl, legacy, clarus, whatever, i need a cheap amp to push my two 12's
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
dbolm666
dbolm666
milford, ma
dbolm666
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
