Please Help!
cjennings
i have 4 power acoustik fubr-12. i need help with what amp or amps do i need to get to power these subs to full potiential...they will be put in a quad ported box and installed into my expedition...PLEASE HELP ME1here are the specs of each subwoofer
1800 watts power handling
800 Watts RMS
200 oz. magnet
2" BASV 4 ohm voice coil
Die cast aluminum
Royal Blue Finish With Diamond Cut
Non-pressed laminated paper cone
Chrome finish back plate
Large foam rubber surround
1-piece rubber gasket
Black poly-cotton spider
Woven tinsel lead through spider
Chrome push terminals
Sound Pressure Level: 91 dB
Frequency Spectrum: 36 Hz
Vas: 1.91 cu.ft.
Qms: 5.71 Qes: 0.502 Qts: 0.462
Xmax: 0.4"
Tuning: 40Hz
Sealed box: 1.2 cu. Ft.
Ported box: 2 cu. Ft.
Port Size (Dia x L): 4" x 8.75"
Number of ports: 1
Mounting Depth: 6.25"
Dimensions (W x H x D): 15.25" x 11.25" x 15"
cjennings
cjennings
Duncan,SC
cjennings
BP1Fanatic
BP1Fanatic
