please help with these grounds
ccapital83
NY
Ok so I have already done my alt to battery and battery ground. I cannot find my motor ground ive searched online and everywhere in my car so. Can i make a new ground for my motor use a different bolt? I found a great easy clean spot thats perfect but the bolt is on the side of the motor which is aluminum im assuming i cant ground there? also i need help i really want to reground my transmission i also see a perfect spot to ground the ****** i want to make sure thats safe to do before i do it. id really appretiate some help if you have time thanks.
any place on the block or ****** is fine. closer to your battery ground/chassis ground is best - and away from heat. leave some flex. protect with high-temp split loom. there are usually unused threaded holes to use in the block or housing. i don't use bolts that are used for brackets.
I was told there is no need to do the ****** cause it is grounded through the motor. I'd rather still do the ****** if there is any possible benefit
thanks for the help saved me alota time and hassle appretiate it i also added 4 guage to my fusebox power and ground with all those new grounds and power wires it feels like a new powerful car i cant believe clean thicker wire can make that much of difference thats crazy.
ccapital83
ccapital83
NY
ccapital83
