Please help with sealed box design two 12"
  • 5
crazyone
Canada
I am planning on building a sealed box for my two orion xtr 12"
It is going in the back of an 03 mustang and I am looking to use as much of the height and width possible so that it isnt too deep. (want to use the trunk for a few other items)
Specs from Orion:
1.5 cb.ft
42.48 liters
1.6cb.ft
45.3 liters
This is the entire trunk space, I would like to use as much of the height and width as possible, and leave as much depth as i can.
h 14.3"
w 32.3"
d 29.5"
Thanks in advance,
962
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
915
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
crazyone
crazyone
Canada
NissanKicker
Brendon Jenness
    May 8, 2024
    May 8, 2024
