Please help with my new 2013 Civic.
Iflythewest
I bought a 2013 Civic LX and am disappointed with the rear speakers. The front two sound Much louder than the rear two speakers when faded in the middle. They also put out very little base compared to the front.
I had some Alpine sps 610s installed by car toys in the rear this week that sounded worse than the stock. Less loudness and even less bass. I know they should be properly amped but was expecting some improvement.
The car toys guy said today that it must be a Honda crossover in the stock system limiting the rear deck to get sound and bass. Is this true? I understand stock speakers are less than stellar but the aftermarket sounded even worse in the rear. I put the stock speakers back in. Thoughts??
Really not a way around it unless you get your own headunit (bypass factory amp) or get a amp (bypass factory amp)
Its probably true that they are crossed over a little bit too high
I'm pretty sure the Amish know more about designing a sound system than car companies do.
This is a true statement. EXCEPT DAT KIA DAT GOT BEATS BY DRE AUDIO !!!!!!!zz1
If I have all four speakers upgraded to alpine with a 45 watt by 4 alpine amp, won't the radio head unit still fade and crossover like the stock speakers sound?
If that is in fact the part that is crossing over the signal yes and no. You could correct it on your amp But I have seen the headunits on some of the older civics (2010ish) and they did not seem like they would have any EQ or xover settings.
My guess is that there is a small amp somewhere powering the speakers and that has a built in crossover. Amping your speakers by themselves would bypass that amp and you now would control everything those speakers see with your own amp.
Also, just get a headunit. No point in not having one if you are seriously looking for good sound.
If your 2013 civic has premium sound the amp is under the driver side dash. Look up and its a little black box about the size of a cd case or a little bigger. I bet it has crossovers built in and would be surprised if you could adjust them, but I really doubt it. Your better off with a new amp and some speakers if your not happy with factory sound.
Iflythewest
Iflythewest
Tacoma WA
blowthemup
