Please Help Me!!!
  • 2
Lewbrah485
hello, a friend and i installed my system (2 12's) today into my 1997 Toyota Camry and we got all the wires where they need to be. I bought a wiring harness and made the connections and when i went to turn on my deck......NOTHING!! I checked the wires again and again and time after time i have no power to my deck. I checked my fuses thinking maybe i blew one and i have found 3 so far that were burned and i replaced them and still nothing!!! It has to be a fuse or fuse wire right?? B/c my dome light is out as well but every other electrical thing still works. My question is could there be more fuses blown or is it a fuse wire that i need to replace??? Please help me b/c i have been workin on my car for a long time w/ no results!! THANX!
Originally posted by Lewbrah485 hello, a friend and i installed my system (2 12's) today into my 1997 Toyota Camry and we got all the wires where they need to be. I bought a wiring harness and made the connections and when i went to turn on my deck......NOTHING!! I checked the wires again and again and time after time i have no power to my deck. I checked my fuses thinking maybe i blew one and i have found 3 so far that were burned and i replaced them and still nothing!!! It has to be a fuse or fuse wire right?? B/c my dome light is out as well but every other electrical thing still works. My question is could there be more fuses blown or is it a fuse wire that i need to replace??? Please help me b/c i have been workin on my car for a long time w/ no results!! THANX!
i had the same problem. it sounds like the fuse is blown, try to put in a bigger one. i think that the dome light is connected to the fuse that also protects the radio.
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
Lewbrah485
Lewbrah485
Pittsburgh, PA
richie1
