Please help me?
Alright I don't know a lot about systems. I have 2 10's and kickers in the front doors, the 10's and kickers are hooked up to my amp. My amp's only a 450so it's kinda small, the other day it started cutting out to where it was only playing through the back door speakers(the only ones not hooked up to the amp) and it did it again and never started playing back through the other speakers, anyone wanna help me out a little?
So you are running a pair of 10s and door speakers off of that amp? You are probably running that amp at a lower ohm load than it is designed for....Use the amp for the 10s only and hook the front speakers up to the deck's front channel and see if problem goes away....
It is likely a 4 channel amp. Verify the model number and share pics of the amp wiring.
Look at the amp to see if the light is on. If you don't have or know how to use a DMM, either learn or pay someone. That is the tool required to troubleshoot.
DrewHarrington
DrewHarrington
Merryville, LA
keep_hope_alive
vegang
vegang
