please help me with a 2 ohm wiring diagram
pick-axis
I have two kicker 10's SVC (10C104) and one Rockford fosgate 12 DVC (T112D4). My amp is a JBL GTR-1001
Will someone please help figure out a wiring diagram for a 2ohm load for all three of these if it is possible. Thank you very much to for all input and thought put into this query!!! Below are links to everything in this setup:
https://www.jbl.com/car-amplifiers/GTR-1001_.html
https://www.manualslib.com/manual/514163/Rockford-Fosgate-T110d4.html?page=6#manual
https://www.manualslib.com/manual/515254/Kicker-Comp8.html?page=2#manual
I have two kicker 10's SVC (10C104) and one Rockford fosgate 12 DVC (T112D4). My amp is a JBL GTR-1001Will someone please help figure out a wiring diagram for a 2ohm load for all three of these if it is possible. Thank you very much to for all input and thought put into this query!!! Below are links to everything in this setup:
On one channel connect your two kicker svc run wire positive to other speaker positive and to your amps positive then do the same thing with your negatives ..all to amps one side ..with your dvc you’ll do the same thing to your amps other side ..but both of your connector sets are on the one sub ..pos to pos to amp then neg to neg to amp ..your amp will then see a two ohm load from the speakers
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
pick-axis
pick-axis
Chattanooga, TN
garychoffmann
