Please help me w/ choosing speakers for this amp. ..
  • 1
SoCaL081
50
I recently received a Kenwood KAC-7005PS 5-Channel amp that I am hooking up in my SUV but could use some insight/recommendations on what 6.5" speakers or components I should get for this amp. I have currently have (4) 6.5" pioneer premier speakers (old old ones) in my suv but may only use the (2) up front. The sub channel will be running a single 12" Eclipse SW8122DVC sub wired to 2 ohms @ 500w rms. So im looking for some good, loud, and somewhat cheap mid/highs that will run ok with my amp. Heres the amp specs...
  • 40 watts RMS x 4 at 4 ohms + 300 watts x 1 at 4 ohms
  • 50 watts RMS x 4 at 2 ohms + 500 watts RMS x 1 at 2 ohms
  • 100 watts RMS x 2 bridged at 4 ohms + 500 watts RMS x 1 at 2 ohms
More info:
918
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
901
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
SoCaL081
SoCaL081
SoCaL081
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
