Please help me decide which sub to get!
have you gone to the SSA store? You should look at the woofers there before you decide. There's also PSI which I would recommend. Since you are in Florida you might want to join Floridaspl, a lot of people there from WPB
The sound deadening is going to be more about preventing vibration from metal surfaces and adding unwanted noise. Does it have the JBL system...
It's called the K.I.S.S. preciniple ("Keep it simple, stupid!")... Takes the guesswork out of parallel/series wiring.
958
As for which signal to use, I tried all combinations and getting signal from the dash and front & rear doors is the only way the system sounded...
15
UrMomsUnclesDad
UrMomsUnclesDad
WPB, Florida
mclerico83
    May 18, 2024
    May 18, 2024
