Please help, harness is missing two pins
udmm54
My metra harness is missing A03 and A04. are these usually not needed? thanks. btw this is a reverse harness going into the factory radio
A01: Yellow/Green: Radio Switch
A02: Yellow/Red: ACC (Main stereo power supply)
A03: Green/Red: Radio Remote Switch
A04: Red/White: (Security Input)
A05: Pink: Right Rear Speaker +
A06: Blue/White: Left Rear Speaker +
A07: Green/Yellow: Front Passenger's Door Speaker +, Right Tweeter +
A08: Green/Black: Driver Door Speaker +, Left Tweeter +
A09: Red/Black: Lights-on Signal
A10: White/Green: Constant Power
A11: Brown: Radio Remote Switch Ground
A12: Not Used
A13: Not Used
A14: Not Used
A15: Blue/Yellow: Right Rear Speaker -
A16: Blue/Black: Left Rear Speaker -
A17: Gray: Front Passenger Door Speaker -, Right Tweeter -
A18: Light Green: Driver Door Speaker -, Left Tweeter -
A19: Red: Dash Lights Brightness Controller
A20: Black: Ground
dont buy metra. they falsely adverstise
Dude, you probley orderd the wrong harness for your car. Metra makes so good stuff. The only thing I do not like they make is smart harnesses because the unpin in no time.
Second there is a reason why those pins are blank on Metra harness. The A04 pin (Security Input) is not needed for an aftermarket radio. It is the status light on the factory radio to indacate that the factory alarm is armed and that if the raido is stolen it has to have a code entered in for it to work. A03 is for factory steering wheel controls.
udmm54
udmm54
Central NJ
Mike465
