please critique my setup I am planning.
Greggk
An ARMY NCO 24/7
I am very new to Home audio past walmart surround sounds.
I currently have a simple LG bluray surround sound sytem.
I am not looking for superior studio/concert results, just a lot better than what I have now.
So this is the plan:
Keeping the receiver for my current Surround sound and ditching all the speakers for it.
i will be doing 4 satelites with the Tang Band Bamboo cone 4" speakers
Tang Band W4-1320SIF 4" Bamboo Full Range Speaker 264-914
and with Vifa XT25BG60-04 1" Shielded Dual Ring Radiator Tweeter
Vifa XT25BG60-04 1" Shielded Dual Ring Radiator Tweeter 264-1012
in Dayton Audio TW-0.25CH 0.25 ft³ 2-Way Speaker Cabinet Pair Cherry
Dayton Audio TW-0.25CH 0.25 ft³ 2-Way Cabinet Pair Cherry 302-702
with these terminals Dayton Audio BPA-38G HD Binding Post Pair Gold
Dayton Audio BPA-38G HD Binding Post Pair Gold 091-1245
these satelites will have crossovers built for them, and will be powered by my current receiver.
then we are doing this setup for the sub
the Behringer EP4000 Europower Power Amplifier 2 x 1400W
Behringer EP4000 Europower Power Amplifier 2 x 1400W 248-748
with the Behringer SUPER-X PRO CX2310 Crossover
Behringer SUPER-X PRO CX2310 Crossover | Musician's Friend
will power a single 15" Alpine SWR-1522D
Alpine SWR-1522D Type-R 15" subwoofer with dual 2-ohm voice coils at Crutchfield.com
in a custom made vented box.
So what do you think?
I would buy one of these for HT way before the alpine... You could even look at 2 of them.
Dayton Audio RSS390HO-4 15" Reference HO Subwoofer 4 Ohm 295-469
Dayton Audio UM15-22 15" Ultimax DVC Subwoofer 2 ohm Per Coi 295-514
I haven't ever used any of the tang band speakers but I have heard the underhungs and they sounded great. As far as the dayton box etc I believe you can buy full setups you just have to put everything in. They come with the woofer, tweeter, crossover, sound foam, and the cabinet and it is all tuned to work together all ready. Dayton makes sevferal of them I believe so that could be a route to look into.
Those dayton woofers are VERY nice. I would run the HF version before the HO though. The alpine is fine if all you're looking for is output but in a home theater setup SQ is critical and they lack in that area. Go Dayton, they set the standard in DIY home audio IMO.
i am not trying to argue, you guys probably know more than I do. This is the same setup my buddy essentially built for his movie theater in his house. I was looking at the stats on the 2 subs
here is Alpine Type R 15"
Features and Specification
SPECIFICATIONS
Power Handling Power Range: 400 - 750 Watts
RMS Power Handling: 750 Watts
Peak Power Handling: 2000 Watts
Dimensions Mounting Depth: 234 mm (9.2'')
Mounting Diameter: 349 mm (13.8'')
Displacement: 0.123 cu. ft. (Front Mount)
Added Volume: 0160 cu. ft. (Reverse Mount, Magnet Out)
General Frequency Response: 20Hz - 400Hz
FEATURES
Diaphram Material: Kevlar Reinforced Pulp Fiber
Design: 2-Piece Structural Parabolic
Surround Material: Injected Molded SantopreneA?
Design: High Amplitude Multi-Roll
Spider Material: NomexA?
Design: Mirrored Progressive
Voice Coil Material: 180A?C High Temp Wire on Spiral Cut Aluminum Former
Design: 4-Layer Dual Voice Coil
Motor Structure Pole Geometry: Compound Radius Curve (Patent #6 ,639,993)
Configuration: Radial Vented VC Heat Sink and Airflow Management System (Patent Pending)
Frame Material: Cast Aluminum
Design: Perimeter Vented Heat Transfer (Patent Pending)
Terminals Layout: One Side
Design: Heavy Duty 8 gauge Push with Housing, Banana Plug Jumper
Tinsel Leads Design: Reinforced Layer Spider Integration (Patent #6 ,810,988)
Gasket Design: Concealed Mount Gasket System
Power Handling (RMS)
800 Watts
Power Handling (max)
1,600 Watts
Impedance
4 ohms
Frequency Response
21 to 600 Hz
Sensitivity
87 dB 1W/1m
Voice Coil Diameter
2.5"
Magnet Weight
150 oz.
THIELE-SMALL PARAMETERS
Resonant Frequency (Fs)
24.2 Hz
DC Resistance (Re)
3.3 ohms
Voice Coil Inductance (Le)
1.83 mH
Mechanical Q (Qms)
4.48
Electromagnetic Q (Qes)
0.42
Total Q (Qts)
0.39
Compliance Equivalent Volume (Vas)
3.87 ft.³
Mechanical Compliance of Suspension (Cms)
0.11 mm/N
BL Product (BL)
21.52 Tm
Diaphragm Mass Inc. Airload (Mms)
380.6g
Maximum Linear Excursion (Xmax)
12 mm
Surface Area of Cone (Sd)
829.6 cm²
MATERIALS OF CONSTRUCTION
Cone Material
Aluminum
Surround Material
Rubber
Voice Coil Wire Material
Copper
Voice Coil Former
Aluminum
Basket / Frame Material
Cast Aluminum
Magnet Material
Ferrite
MOUNTING INFORMATION
Overall Outside Diameter
15.29"
Baffle Cutout Diameter
14.01"
Depth
7.01"
# Mounting Holes
8
OPTIMUM CABINET SIZE *
Sealed Volume
0.95 ft.³
Sealed F3
3 Hz
Vented Volume
2.72 ft.³
Vented F3
30 Hz
* Enclosure volume/F3s based on BassBox "optimum" calculations
Can someone explain the difference to me? The sub will be made in a custom designed box using an enclosure program, not a prefab box.
can you tell me where you are seeing this. I am trying to learn this so please dont get hostile. I am looking at the frequency response range
Alpine 20-400hz
Dayton 21-600hz.
600hz is more highs, than the alpine, but according to manufacturer specs the alpine says it goes 1 hz lower than the dayton.
sensitivity is both 87db nd sub excursion is 20.7mm for the alpine and 12.1mm for the Dayton
Different tools as well as gizmos announced the longer term ended up being the following as well as liberated females via numerous burdensome residence responsibilities. Homemaking,christian louboutin shoes, the item appeared, were and so negative if you got power ranges,christian louboutin bags for cheap, cleaner cleaners,Christian Louboutin Flats, refrigerators, and so on. Females may possibly at this point give full attention to setting up a secure residence thus to their individuals,christian louboutin crossbodys, as well as continue to include time frame to get the lifetime without using this kitchen's.
During this springtime period 50 % sleeves is the most frequent models. Some people are available in dazzling patterns along with coloration behaviour. The leading concept will probably be anything associated with springtime as well as expounding on the actual magnificence with the period. Springtime is termed as being the california king of months, the top in reality having a pleasurable local climate. Skinny jeans along with shed trousers usually are favorite during this period.
Greggk
An ARMY NCO 24/7
Greggk
Ludowici, GA
cons33756
