playstation installatio
chinxtaboi
tx
k, i wanna install a playstation in my ride.... how do i go bout doin that???
any help appreciated.
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif//content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
iight i wanna hook up a playstation in a yukon denali....
i got the flip down tv with tv tuner and everything, fm modulator, and dvd player
how would i hook up the playstation?
Originally posted by chinxtaboi iight i wanna hook up a playstation in a yukon denali....
You will need a power converter for starters. Something that will change over the 12volts to 110 so you can actually run the playstation. Then you need to set up a run from where you are mounting the playstation to the input on either the tv tuner or fm modulator. More info on what set up you have specifically would be better to know where you are going to connect this in, but you may or may not even end up needing a switch. It all depends more on the set up.
i think i got it... thanks for all da input
//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif :D
chinxtaboi
chinxtaboi
tx
chinxtaboi
