Plastic/Carpet Trunk lining Removal?
brandontw
just some guy
2,997
Reno, NV
Im trying to fix up my trunk with all of my gear but this daamn molded plastic carpet trunk lining or whatever it is called is very troublesome. I looked into taking it all out but i think my trunk might look and sound like a ***** if i take this all out. it will probly echo and rattle alot. not to mention looking crappy because there is all these wire for tail lights and whatever else bihind it not hidden at all( its an 88 taurus crap mobile). I cant really afford dynamat yet or id just rip all that crap out and replace it with dynamatt.
Should i just go ahead and take it out so i can install the stuff right. would it sound that bad?
or other suggestions?
During my replacement of a factory sub I had my factory plastic enclosure just sitting in the back with my new sub just sitting in it loosely and...
3 ways. 1st is to use a piece of copper or PVC tube shorter than the drill bit. Press it hard into the carpet and set the bit inside it. If you...
32
That's not a bad idea. I can get glass resin cheaper than cld sheets too. I could put cld over the glass to add more weight without having to just...
20
627
I too generally use the factory carpet to make my templates. It's also a good idea to put layer of butyl damping material under the MDF too...
7
935
If the amp is already part of the unit, with the amp built in, you would need a power supply, something like this: Or sell that amp amp and...
brandontw
just some guy
brandontw
Reno, NV
brandontw
Bobbytwonames
    Jul 26, 2024
Bobbytwonames
    Jul 26, 2024
