OP
shdowflare
- Thread Starter
- #16
Okay guys, I have to switch gears for a second...
I was pretty set on getting a pair of JL Audio HD amps (750 and 600) to take care of my four main channels and the sub channel, however it turns out that I am able to get a great deal on the Polk PA1100.5...
That said, will it work for my requirements? As of now, I think I'm going to get two 4080 enclosures, and put JL 10w1v2-4 woofers in them. Would the Polk amp be able to power the four main channels (125x4@2ohms), in addition to two woofers on the sub channel? Seems like a lot for one amp to handle. Keep in mind those JL subs run 150w RMS each @ 4 ohms. I was thinking I could hook them up in parallel so they run at 2 ohms. The Polk amp runs 600x1@1ohm for the sub channel. Is this a good option to power my system? I will literally spend like $200 for my amplifier needs vs. about $1000 for those JL HD's. But I want to make sure it's gonna work!
As for physical fitting, based on some other G35 owners pics of the JL 500/5 mounted in the OEM Bose amp location I think the Polk amp would actually fit in there (though it'd be tight). It's six inches longer than the JL, but I think there's some room to extend a bit more if necessary, as noted from the pics I saw.
Thanks!
Brian
Thanks!
Brian
