Planet Audio HVT-754
buildmeabox
This unit has four channels with 70 watts output each. The tubes are used for the preamplifier input and solid state MOSFET for the output. With built in high pass and low pass crossovers, variable subwoofer boost, tri-mode and bridged mono mode, this is one very flexible amp. Very nice natural sounding amp, the warm sound is sweet, open and detailed, very hard to find in this condition specs and info below.
Will accept trades or cash $300, only trades I'm looking for are JL Audio 500/5, JL Audio 300/4 or six channel amps.
Hybrid vacuum tube four-channel amplifier
RMS power (4 Ohm): 70 watts x 4 at 0.01% T.H.D.
RMS power (2 Ohm): 100 watts x 4 at 0.01% T.H.D.
Bridged power (4 Ohm): 200 watts x 2
Signal to noise ratio: 103 dB
Frequency response: 10 Hz to 100 Hz
Tri-mode operation
Built in continuously variable low pass crossover
Built in continuously variable high pass crossover
continuously variable bass boost
Line output with independent continuously variable high/low pass crossover
Gold plated connectors
Dimensions: 14-1/8" (L) x 2-1/2" (H) x 9" (W)
This amp is Zed built and from the mid 90's
[/img]
[/img]
[/img]
[/img]
Price dropped to $225 Shipped, currently using it on a set of Boston Acoustic SubSat6 and the sound is outstanding!!! Lots of power way more than rated and the x-over works equally the same. Somebody wants it...
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
Thanks man I’ll give it a try I’m usually pretty bad at this kind of stuff. I wasn’t sure if there was a website or something that had a picture I...
The siq amps are Sq beast as well. And much cheaper. Made by s&I in Korea iirc
86
buildmeabox
buildmeabox
Houston,TX.
buildmeabox
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
