I'm looking at some amps to power 2 Skar VVX-12s at 2 ohms. Because of the electrical system in my car, I don't think I will be able to run much more than 1200 watts, so I'm just looking for an amp to do 1200 watts at 2 ohms. Came across this
sonicelectronix (dot) com/item_40564_Planet-Audio-BB2400.1-R-B.html
(post won't go through if I post full link for some reason)
Planet Audio Big Bang 2400 watt amp, does 1600 watts at 2 ohms.
The only problem is, the fuse holder in my car is rated at 130A, while the fuse on this amp is 230A. If I were to set the gains on the amp to only push 1200 watts at 2 ohms, the amp would only be drawing ~90A of current. Would that work with my fuse holder, or would I still need a 230A fuse?
Also, recommend some other good amps that can provide ~1200 watts at 2 ohms for around the same price ($250).
