if we all work together we can accompish anything!Hi my name is rain and I want to cure world hunger. Do you like the dress I bought for the pageant?
Lol...This is concrete ya'llPeople tried to say I would fall
I be hittin you up with knowledge
Even though bishes say I can't attend college
I don't need math or physics
To show you I'm with it
You keep going on trying to imply
While I know that bish won't fly
Wrong. And even if your idea were right, 120x2 would be 240, not 220.not much of a math wizard but saying if the belt is moving at take off speed (idk lets say 120mph) and the plain was not started it would be moving backwards at 120 mph.(sounds stupid i know and probably wouldt sit still) but if the plain engine was started and got to take off speed (same as belt) it would become stationary like a hamster on a treadmill, moving but sationary. it would then need to accelerate to 220 to achieve a momentum or actual speed of 120 with relevance of air speed. i hope im being clear
There is no connection, there is no black magic, they are TWO SEPARATE FORCES YOU TARD!!!I see the point being made. The plane and thrust is no reliant on the belt. PERIOD. If it was flying. But I think it add more to it when you make a connection between the plane and the belt.
PLANE
_____
obviously if the plane is flying over the belt, it will have no effect on the plane at all.
And I think that with the wheels actually sitting on the belt (regardless of wheel speed), that the plane will not be able to take off.
HOWEVER
I do see what you guys are implying, but I think that you do not understand what difference the connection between the plane and belt are making. The wheel structure acts as bridge between them, with the wheels there to allow movement and reduce friction. That bridge provides a connection between ground and air speed, and because it has that connection, it has to apply to ground speed until it has enough speed to overcome the ground, and become an object relative to air speed.
Corrected. //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gifEither way, I will find out on the 30th.
Thats actually one of the best examples I have heard yet...look at it this way.
Your on a treadmill running. You go nowhere right? Your legs are the driving force.
You strap a jetpack onto your back. Turn it on. Does it matter what your legs do at this point? even if they are on the treadmill, your going forward. You're not going to backward because the treadmill is pushing your legs back. Your going to be moving forward.
The wheels on the plane have absolutely nothing to do with it.
Horrible example, but the point is the wheels don't drive the plane.
What the hell are you trying to explain then?I am not going to attempt to expain my reasoning behind my opinion. It is apperant that none of you see what I am actually trying to get accross. This may be due to the fact that I am not explaining my point very good. Either way, we will find out on the 30th.
