Places to put subs
And to daboy, I guess you're right. I just don't want to take my seat out and everything and then be like oh hell I can't put a sub back there. Do you think there is enough room for a shallow mount or whatever it's called?
It's an 02. I already have 2 subs in a downfire box. I just like bass a little too much //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif so I'm trying to get more. And what about installing another box between my existing one and my front seats? Has anyone tried that?
If I'm picturing my friend's extended cab correctly when I did his subs (under seat box but I mounted the amps to the rear wall). You should be able to fit some shallow mounts back there, pending on your box. If you build the box, with the proper measurements, you'll be fine. Trying to find a prefab may be difficult as it does need to taper pretty thin at the top. Don't quote me on anything here, just going off slight memory.
harvey1795
harvey1795
United States
mopower440
vegang
vegang
