Pioneer Premier DEH-P4901B
  • 4
Kool
I just this deck today used at my local car audio store for $150.00. i just set it up and it works good but the cd text doesn't work. I've noticed this with my last deck too. Does anyone else have this problem with pioneer decks? I mean it's a good deck but I would like it more if the cd text worked.
i never use this feature but if its a burned cd dont you have to burn it a special way..
like in itunes i believe u need to select the burn cd text feature or something
not sure if this is right so please dont hold this against me.. but in itunes go under edit=>prefrences=>advanced=>include cd text
i never use this feature but if its a burned cd dont you have to burn it a special way..like in itunes i believe u need to select the burn cd text feature or something
I don't use itunes.
You might have to turn it off and hold function for a few seconds. Itll want you to change the time so go past that to the other changeable options. If its not there try holding audio or display. That or rtfm.
I use Waze on my 1500 NEX. The one time I did have issues I had to delete weblink and redownload it. I have location to "while using" on weblink app.
491
Google can... Query DEH-X1850UB faceplate replacement.
How old is the unit? My Pioneer died last month (manufacture date April 2021). Apparently they had component supply problems after Covid and...
918
Kool
Kool
Michigan, U.S.A.
nismos14
