here are the details .
MP3 and WMA Playback
Pioneer DEH6900 Description:
Detachable Flip-Down Faceplate
MOSFET 50W x 4 Maximum Power
XM Radio Ready with 2nd Generation Display
Credit Card Sized Remote Included
Optional Wired Remote
Pop-Up Rotary Volume Control
EEQ Performance Chip
3-Band Parametric Equalizer (Adjustable Level, Frequency, and Q Factor)
Easy EQ (EEQ) switches 5 Factory and 2 User EQ Presets (Super Bass, Powerful, Natural, Vocal, Flat, Custom 1, Custom 2)
Source Custom EQ Memory (Independent Custom Memory for Each Source)
EQ-EX Feature For Enhanced EQ Effect
SFEQ (Sound Focus EQ)
Additional Independent Bass / Treble Control for Front and Rear
NEW! BMX (Bit Media Expansion) Technology
Digital Compression for MP3 and WMA Playback
BMX1 Mode Enhances the Depth and Width of the Sound
BMX2 Mode Improves the Sense of Presence
Three Sets of 2-Volt RCA Preouts (Front, Rear, and Sub)
Front/Rear High-Pass Filter (50/80/125Hz, 12dB/oct.)
Selectable Low-Pass Filter (50/80/125Hz, 18dB/oct.)
Sub-Out Level (-12dB to +12dB) with Phase Control
IP-Bus System Control
XM Satellite Tuner Ready
CD Changer / DVD Control
Auxiliary Input (CD-RB10 or CD-RB20 required)
2 External Unit Control
S.L.A. (Source Level Adjustment)
Selectable Fader Control
Organic EL Display (128 x 33 pixel)
Full-Motion 3D Graphic Animations Including 2 Screensavers
2 Level Meters and 4 Background Animations
16-Character Text Display with Adjustable Brightness Level
White Backlight for Increased Contrast
24 x 33 pixel Auxiliary Display with Soft Key Feature
Compact Disc:
Disc/Folder Random Play
Audible Fast Forward/Reverse
Playback Compatible with Digital CD-R and CD-RW
Disc Title Memory (48 Discs)
CD Text and ID3 Tag Display
WMA / .WAV CD-ROM Playback
3-Beam Laser Pick-Up with AGC (Automatic Gain Control)
1-Bit D/A Converter with 8x Oversampling
Anti-Shock Mechanism
Radio:
Supertuner IIID with Digital Processing
Significantly Less Distortion Than An Ordinary Tuner
Increased Signal-To-Noise (S/N) Ratio
Reduced Multi-Path Noise
Improved Sensitivity and Stereo Separation
24-Station / 6-Button (18FM / 6AM) Presets
BSM (Best Station Memory)
Up / Down Seek with Selectable Local Seek Tuning
