Pioneer DEH-2900 Won't Power On???
Acizzle423
Ok, so I took this to my boy for him to install it. He is pretty knowledgeable in car audio, so I trust him. Anyways, I have to wire mines different from most players. The guy who did my install before cut my factory harness, BIG "NO-NO", but that's my fault for trying to save money. //content.invisioncic.com/y282845/emoticons/mad.gif.c18f003ab0ef8a0d9c27ca78d77a6392.gif Anyways, I just took out my old Eclipse unit and hooked this one up just like the Eclipse H/U was. We could tell what goes where because of a guide telling which factory wire goes to what after market wire. Well, we get it hooked up and everything, plug up the H/U and wha-la, nothing!//content.invisioncic.com/y282845/emoticons/eyebrow.gif.fe2c18d8720fe8c7eaed347b21ea05a5.gif
SO we made sure to make sure EVERYTHING was correct. Ground=Check, Battery=Check, ACC=Check. Everything is correct for the unit to power on, but it won't even do that. Made sure I had a good ground and tried to connect to the chassis, but still no luck.
I'm bummed, but will run by a professional shop tomorrow, even though I know my friend is pretty good. But, any tips or anything that I could try before tomorrow afternoon. Sure sucks having no bump in the car even though it's been one day. //content.invisioncic.com/y282845/emoticons/crying.gif.ec0ebefe590df0251476573bc49e46d8.gif
wires may be connected ok, but do you have a multi meter, etc. to actually see if you are getting power ?
before makeing a new thread, i would have checked that out first. //content.invisioncic.com/y282845/emoticons/idea.gif.5acb6a39a9b92425414c316dda202bad.gif
^So there's a possibility the fuse on the new H/U is bad? I'll check that out. As for a DMM meter I don't think I have one, but I would suppose I need to invest in one.
Acizzle423
Acizzle423
Chattanooga,TN
Acizzle423
