Pioneer AVH-X3800BHS turns off signal to my amp when going from park into drive.
rjeftw
Installed today and I am quite confused on this whole situation; Found out 1 of my channels had died since I last used my amp, but I just wired my rear doors together. Everything is fine until I put the car into drive. I did not wire up the Parking brake or reverse wire... not sure why that might if that would actually cause the issue or not.
2012 Hyundai Sonata GLS, Metra 70-7304 harness, Knukoncepts RCAS, PPI 900.4.
Any help would be greatly appreciated, I will be going back at tomorrow morning!
Thanks!
Okay, appears it goes into protect upon shifting into D and start going forward. Checked over my wiring... Ran a new remote wire too. Everything appears to be in order. Only thing I can think of is my ground is ****, or my battery/alt are going out. Going to pull my ground off once I get off work then I guess resand the area see if that improves this.... otherwise I am completely lost.
Yeah it sounds amp related... the change of rpms changes the voltage so the change could be doing something... get alt checked I don't think its that if u don't have any other electrical like dash lights going out...a/c not working or Windows being extra slow
Mr. 10K
rjeftw
rjeftw
Orlando
10k-watts
