Piece of crap DVM doesnt work.
only thing that comes to mind is the remote wire should be connected to ground. In order to measure a voltage, (or power something, like the display on that distro), you need a + and a - (ground). with the REM connection hooked up to the HU remote wire, it will not have a -. (the + comes from the power wire in the distro).
Maybe try to research that alittle. Or give the people at Audio Pipe a call.
Yes, as everyone else said...in order for it to work, it'll need to be grounded some where.
Are you sure that's an REM wire and not a ground wire? Reason for it shutting down could be that when you turn the radio on, the REM wire is putting 12VDC into the wire that is actually a ground.
flakko
Veteran (my butt)
flakko
So Cal
flakko
