This turned out awesome for me:I haven't read everything in here.... but can i get a cliff on how to get a textured paint job look? There's no lowes over here, only home depot and i know they sell some textured paint.
so is it just 1) primer
2) one layer of "textured" paint?
or is it more complicated than this?
how many cans would i need for a 4ft/cu box?
i'm tired of the black cheap carpet that cost too much
1) Fill all holes with quick-dry spackle, route all corners/ edges with a simple 1/4" round to take the edge off, sand with an electric sander & big grit paper (no need to really perfect it since we're gonna add a texture anyway)
2) Cover the whole box with spray can of dark gray or black primer
3) Cover the whole box with spray can of dark gray or black "textured" spray paint (color doesn't matter too much, but dark is better in case your box gets bumps or gashes, so a lite color won't show thru a gouge)
4) Again cover the whole box with a final coat of dark gray primer
I know primer is not supposed to be the final coat, but it is for me & works great; It's super flat, no shine, & is perfectly uniform looking. The charcoal looking final color matches my charcoal/ dark gray/ black interior great. Very professional looking if I don't mind sayin' so myself. My friends say "Holy cow, where'd you get the box?"
I was glad this way ended up so good, because I was not looking forward to trying to carpet or upholster it.
sure i'm gonna take pics and put them in my build logPretty creative technique there. However if your getting an uneven or sloppy texture with your paint your doing it wrong![]()
I'll have to try this out sometime though to see if there something to this.....
@Xprime
Just play around on some scrap wood until you get what your looking for. Their are waaay to many things that effect painting especially give your climate vs mine. Try a solid 2-3 coats of primer followed by 1 coat of textured. The type of paint you purchase will play a huge role in the # of coats needed that's why theirs a little bit of guesswork.
Just remember to spray in 1 direction, then altenate to the section below (slightly overlapping) and alternate to the other direction. Keep the hand motion fairly quick and your golden
Post up some pics when your done
I realized the sub needed more clearance from the back wall of the box.why the extra ring on the outside?
what primer did you useI realized the sub needed more clearance from the back wall of the box.
If you're talking about extra glue squishing out, just wipe it off with a damp paper towel or cloth as you go. And, after it's dry it sands just fine when you're sanding the rest of the box. Use an electric sander, and sanding is actually tolerable.sure i'm gonna take pics and put them in my build log
I'm not quite sure about the something. The mdf piece that glue together always bring some over glue and sink on the side. I usualy wait till its dry then i remove it why a razor, but there's always some leftover. It doesn't really paint well. What should i do for that? same with silicone
Just sand all that with like a 100-150 grit. Sanding in between coats helps aswellI'm not quite sure about the something. The mdf piece that glue together always bring some over glue and sink on the side. I usualy wait till its dry then i remove it why a razor, but there's always some leftover. It doesn't really paint well. What should i do for that? same with silicone
Nice! I'll have to go check your buildlog out now that you got your sub in
