Pics!!!!!!!!!!!!!!!
Looks like a nice job. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
BTW, your sig is a bit too big.
by 25 pixels which is 1/3 of an inch
you guys are nazi's //content.invisioncic.com/y282845/emoticons/rolleyes.gif.c1fef805e9d1464d377451cd5bc18bfb.gif
i like it too. cept the false wall doesnt go all the way to the side of the trunk there on the left. and that port thing.
otherwise, i like it alot.
oh yea your sig is too large, fix it
lol mr symetrical //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif its not tastlessly done though . did crossfire get back with u?
i really like the install simple, clean and with some design to it.
yes the port needs some more black to it, but that should be an easy fix.
i don't know if its the angle the pic was taken, but the amp rack wall closest to the sub seems to be too high like an 1 1/2" to high or too close to the sub.
some thing that would look awesome is Plexiglas over the amps with laminate trim around the amps covering the gaps around the amps. and maybe a PG logo cut out on it, for ventilation.
again very nice setup, i love JL audio.
i really like the install simple, clean and with some design to it. yes the port needs some more black to it, but that should be an easy fix.
Very good suggestions, I was also debating the plexiglass. Maybe later down the road, and yeah i belive its the angle of the picture. Thx 4 the feed back!
Can you possibly describe how you did that panel / false wall in the trunk? I am trying to design one now for Remy Acura but am having problems figuring out the best way to do it.
How does it stay upwards? I assume some brackets that are attatched to the floor and ceiling behind the wall?
Also how about some detail on how you installed the amps on the trunk floor and created a false bottom.
Are their any DIY's on this stuff. It would be great if there was.
My first install if you cannot tell. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Can you possibly describe how you did that panel / false wall in the trunk? I am trying to design one now for Remy Acura but am having problems figuring out the best way to do it. How does it stay upwards? I assume some brackets that are attatched to the floor and ceiling behind the wall?
Ted... HiFi buys in fayetteville ga. I watched the install of the trim panel wall and what he did was measue and cut out a pattern of paper then cut the wood based on the paper. It was then attatched to a piece of wood that the box is sitting on that levels it. A airgun stapler was used. As for the amp rack there is no false bottom its just sitting on top of the spare tire wheel well. Its an illusion that makes it look like its sunk in. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
John3000
John3000
Georgia
60_cent
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
