amartin_72
Banned
I decided to stick the one R in my box for 3 just to see how it sounded. I used the peices that were cutout to plugthe other sub cutouts with a towel in each to seal(worked quite well although i had to hit them inwith a hammer and it probably split my baffle a little) I have it powered with my PA 3000D@2ohms and it is far louderthan my friends 2 r's in 2.5each@35hz and the sound quality with rock is crazy tight in the 60hz range. I have the subsonic filter set alittle high because the huge box really cuts down on the low note power handling but lil jon and young jeezy still pound like no other. I really reccomend a box larger than the current trend of 2-2.5 for the R's. I think around 3ft is optimum for the R's and I will only be putting one more in my box instead of the 3 as i had planned, it will be louder that way anyways.
Ive had 2 in 1.75 each with 15 in^2 port each
2 in 1 each sealed
1 in 2.1 ft @34hz w/38in^2 port
1 12w7 in 1.75ft @ 32hz w/ 24in^2 port
And friends had
2 05 15" L7's in 6ft tuned to 38 hz with an orion 2500d on stock electrical
2 Type R's in 2.5@35hz with 35in port area
And this current setup slaughters all but the L7's which have a slight low note edge but they sound like ***.
2 in 1 each sealed
And friends had
