Picking 4x10" dual
  • Thread starter rosenow
  • Replies 0
  • Views 517
I know this may be in the wrong topic but oh well //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I need some help plz.
I have a 2003 chevy silverado short bed and i'm planning getting new subs for it.
As of right now i only got a.
POWER ACOUSTIC CPT1-4000D CAR MONO BLOCK MONO BLOCK CLASS-D amp
4,000W CRYPT Series Mono Amplifier
4 ohms: 1200 watts x 1 chan
2 ohms: 1700 watts x 1 chan
1 ohm: 2200 watts x 1 chan
Max power output: 4000 watts
Class D Design
Extruded Aluminum Chassis
MOSFET PSU Transistors
Regulated PWM Power Supply
Three-Way Protection Circuitry (short, thermal & overload)
High Pass, Low Pass, and Subsonic Filters
Pre-Amp Outputs
200mV-8V Low Level Inputs
Variable low-pass filter (50-250 Hz, 12 dB/octave)
Subsonic filter (20-50 Hz)
Frequency response: 15-150 Hz
Signal-to-Noise Ratio: 80dB
Phase Shift: 0-180 Degrees
Dash Mount Remote Gain Control
Bridged Synchronization
What subs would sound good and be great. Money isn't a problem.
I was thing about.
Quantum Audio Q10D2SPL 10" 2000W Peak 1000W RMS Dual 2 Ohm
Application: Competition SPL (These are guaranteed to be the loudest subs at this price point)
Diameter: 10"
180 Oz Magnet
Sensitivity: 83 dB
2000 watts peak
1000 watts RMS
Dual voice coil 2 Ohm
Sealed Enclosure: 1.2 Cubic feet
Vented Enclosure: 1.5 cubic feet
Dimensions: 11.02" L (length on top) x 6.08" tall
3 in. Diameter High Temperature 4 Layer Voice Coil
Extreme Excursion Motor Structure And Suspension
F.E.A Reinforced Paper / Kevlar Cone
High Roll Foam Surround
Orange Anti-Resonance Heavy Gauge Basket
Fully Isolated High Excursion Woven Tinsel Leads
Poly-Injected Rigid Dust cap Design
Custom Tooled Rubber Protective Boot
Screw-on Terminals
pole piece ventilation for even more cooling (these subs stay colder and last longer than almost any other sub on the market)
strategically placed vents for great ventilation and cooling
Heavy Gauge Basktet
Layered UV Treated Foam Surrounds eliminates distortion and unwanted noises
High Temperature 4 Layered Voice Coils
Great suspension for deep bass hits
The magnet on this model is 150 % bigger than on the regular qcw models
or
AUDIOPIPE 1200W TXX-BE10 EXT DUAL 4 OHM 10"
One Audiopipe 10" subwoofer
Model # TXX-BE10
Utilizes Audiopipe's new Edge Extension Technology (E.X.T.) - large foam edge surround for increased efficiency and sound pressure
Power rating (Watts): 1200 Max / 600 RMS
Voice coil design: 2.5" 4 layer black aluminum dual 4ohm
Composite cone
Patented pipe style powdered black aluminum basket
100 oz double stack magnet
Frequency response: 26-1000 Hz
Mounting depth: 6.25"
Sensitivity: 88 dB
I would like to see what you guys think.If you have different ideas let me know.
rosenow
rosenow
Jacksonville, fl
rosenow
BP1Fanatic
BP1Fanatic
