Picasso (sp) 2000D
If the subs are dual 4 it would be a 1ohm load. It sounds like what you are saying is, your subs are dual 2 and you have them at 1 ohm each, so you would have a 2ohm load if you wired it in a series. The 2000d puts out 1500@ 2ohm if I am not mistaken. So 750wrms to each sub. Also to answer your second question I would not get a second amp. It would be too much power for those subs, and a significant strain on your charging system.
the 2000ds do more than rated power if im not mistaken, though ive never done a bench test to prove it. not to mention theres a competitor around here with 10 of them, and he's run every single one down to, proving, they are stable to a .35 ohm load.
and your subs would have to be dual 1's, wired together, to have the final outcome of a 1ohm load for the amp.
my pca2000d was an animal. i blew it being a jackass, cant wait to have it sent off for repair to power the btl:naughty:
yes u are correct they are wired to gether to be dual 1's so it should b putting 1000rms to each sub i think witch is what the 07 s15l7 calls for any adia on sp lvls??? its in a 00 durango
witch btw the altinater in them does crank out **** good
the subs are 2000peak and 1000rms
the amp is a 1 channel. output(watts): rms @ 4 ohms 1100x1
rms@ 2 ohms 1500x1 rms @ 4ohms mono 2000x1@ 1ohm
so after that info should i be getting another 2000d?
IMO I think a second amp would be overkill on your electrical system and and the L7s. Also what were coils? you said that you had them wired together to be dual 1. So I will assume that each sub has 2ohm DVCs. So from there you can get a 2ohm or .5ohm load. So 750wrms to each sub is what you would get if you ran 2ohm. I am not sure if the Picasso can handle .5 daily, but you could try, then you would get 1000+ to each sub.
StormUnite
StormUnite
Ny, long island
billyrodriguez
