Phoenix Gold TI10's?
pwr2max
I am basically looking for subs that are very accurate but that also get very loud and based on the deal at the zeb for the pg TI10's i am considering these. Anyways, those of you that have heard them or have them, how do you like them? Do you think they will suit my needs if i run them off of a PG TI800.1? Also, how durable are they (if i get them they will be consantly exposed to sunlight because my car is a hatchback)? thanks.
which would be louder: 2 svc TI10's wired parallel to get a 2 ohm load or 2 dvc TI10's wired in series in then in parallel to get a 4 ohm load. The TI800.1 supposedly puts out 800 wrms at 4 ohms and 1000 wrms at 2 ohms and i do not really want to run it at 1 ohm unless i am absolutely sure that the amp can handle that load while still staying cool or warm.
If PG says it will take one ohm it will take one ohm no problem
The ti series amps have built in fans as well they are awesome amps but cost good $$$ you can get a jbl 1200.1 for nearly 1/2 as much and it puts out may power at 2 ohms rember the dvc ti's will cost you 100 bucks a piece compared to 57.95 for the single coils
I got a Best Price code at the ZEB for the Ti10D's if that's what you would prefer. $57.95 each. The code it: 5P6096
It's only good through June 15th, so you have to hurry. I'm running 2 of them right now & they sound great.
I got a Best Price code at the ZEB for the Ti10D's if that's what you would prefer. $57.95 each. The code it: 5P6096It's only good through June 15th, so you have to hurry. I'm running 2 of them right now & they sound great.
DUDE! SWEET JESUS? $57.95 a piece? ****! $71.95 was my price check - I was debating buying them at that price, but shoot, just a little more than $100 for a pair shipped, I'm all over that. Buying them as I type. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
thanks alot everyone, but do any of you know for a fact if the pg ti amps can handle a 1 ohm load with out getting excessively hot (once again all this stuff is going in the trunk of a hatchback so temp will be critical especially in lots of sun)?
whats wrong with wiring to a 2 ohm load using the svc ti's (i would get more power to the subs that way)? Is it because the amp will get alot hotter at 2 ohms or other loss in performance?
I also made a mistake before...in the owners manual of the ti800.1 it says that it makes 400 watts at 4 ohms and 800 watts at 2 ohms and a dynamic power of 1000 watts at 2 ohms. So woudnt it sound alot better if i wired the subs to 2 ohms using the svc ti's?
pwr2max
pwr2max
Ellicott City, MD
pwr2max
