Phoenix Gold 800.1 - No sound from Subs
05AztecRed
I bought a PG 800.1, mono amp, 600W RMS @ 2-Ohm... I have 3-Phoenix Gold 10" - 250W RMS 4-Ohm DVC subs... I'm using this setup:
I've installed the amp in my trucks and everything is ok. None of the warning LEDs come on, except at inital start up, turns on/off with HU so the remote is good, RCA inputs are in the correct order, and all speaker wires have a good connection.
I can't get any sound to come from the Subs though... Here is what my spec sheet has on it:
I've been told to connect the speaker wires per the spec sheet in the top right corner, but that doesn't work.
Forgot to add: Do I need to adjust the Db gain knobs to ge a sound and than fine tune it, or does the stock settings work?
Any help would be appreciated.
Thanks!
05AztecRed
05AztecRed
Tempe, AZ
slc72005
