Phase knob?
It changes the polarity of the subs. If mounting your subs inverted you can put the phase 180*
It won't hurt anything. But you should keep it at 0 if your wired correctly and sub is mounted normal.
What equipment are you using? It can be done physically (placement of sub), electrically (reversing wiring), electronically (DSP). If your amp has...
786
When in doubt, use an app called Signal Generator and play tones in the tens. The phase will be easier to distinguish.
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
767
I use bass knob all the time. Some songs it's almost all the way down. Some stuff, 80s music, it's all the way up. Different songs bass levels...
14
  • Locked
I dont see a Username and date on any of these pics that the FOR SALE Rules Should Apply. Are these pics off Ebay?? Place those with the pics so...
jersyn82
jersyn82
ohio
SPLBassJunkie
    May 21, 2024
    May 20, 2024
