Pharmacist and Doctors?
whoa oxycotton way more potent than percocet. persoanl experience if you tryin to get ****ed up take a line of oxy. be carefull if u got both you dont want to over do it
basically oxycotton is the handsdown the stongest pain killer except morphine and heroin
actually, I saw a discovery channel show that stated that oxycontin is just a couple molecules away from heroin.....very close.
10mg of oxy is WAY stronger than the other. Alot of peeps chew them, to get the full amount of med's right away, as opposed to swallowing and getting it time released.
do not chew pills that are that potent. theyre time released for a reason...
Oxycontin has oxycodone in it right? Percocet has oxcodone in it? A 20 or a 40? Yea its stronger but what about just a 10? Time release is for *******/people that need them.
Those of you who are saying oxcontin is way more than a percocet are only correct to an extent.
They are the same thing, but at what MG does on OC become better? I am assuming a 10mg OC is the same as a 10mg perc. That is my Q?
Oxycotin > Percs..
If you took about 80MG of Percs it would equal about 2.5MG of cotin.
An codine is not the same as cotin, I believe codine is basically a Tylenol 3.
Also as someone else said don't chew the oxycotin, you can and people have died from it. You need to let it time release as it was designed to do.. Infact if you get a legit prescription it has a big orange stick that says DO NOT CHEW, CAN DIE! or something to that effect.
I have been on both for the last two weeks and I hate Oxy.Didn't do squat for the broken leg, but Perc helps out with the pain. Maybe it is just me, but they do nothing but help ease the pain and nothing else. I do not understand how someone can take these for anything but pain relief? I am glad though.
Oxycotin > Percs..
Ok dumbass.. percocet does not have codeine, and 2.5 of OC sure as **** dont equall 8 percs.
BTW codeine is not like a tylenol 3 either.
And all it does with chewing OC's is not using the time release. It will not kill you, the time release on an OC 10 will give you 5 mil the first 6 hours and 5 mil the second 6 hours. Do not post unless you know WTF you are talking about.
Perocet is OXYCODONE
Oxycontin is OXYCODONE
WHAT MG OC DOES A PERC 10 EQUAL?!?!?
22mountaineer
6 /\
22mountaineer
North AL
crunktimes.com
